GOS 10 Hub Power Connection
If needed, you can extend the power wires using 18 AWG (0.75 mm²) wire with solder and heat shrink or waterproof connectors.
Wiring diagram with callouts
Item
Description
Notes
1
GOS™ 10 hub
NOTICE
You must connect the GOS 10 hub to the same power source as the engines for the engine cutoff functionality to work properly.
2
Engine or engines
3
GOS 10 hub power and engine wiring harness
Red: positive (+)
Black: ground (-)
4
1 A fuse or breaker
You must connect the positive wire to power through either the included inline 1 A fuse, or through a 1 A breaker.
If you connect the power wire to a breaker, you should remove the inline fuse.
5
Ignition or external switch
The GOS 10 hub does not turn off with the NMEA 2000® network or with other Garmin® devices. You must connect the power wire through either an accessory switch or a separate physical switch.
NOTICE
Connecting the power wires directly to the battery will drain the boat battery when the boat is not in use.
6
12 Vdc power source
GUID-7D06FCCD-97F4-4DD5-9900-79121558C4B8 v3
August 2026
