Tools Needed
Drill and a 2 mm (5/64 in.) drill bit
Wire cutters and strippers
Marine grade tap splice connector for 22 AWG wire or solder and heat-shrink tubing
Cable ties
#2 Phillips screwdriver for mounting the GOS™ 10 hub
#1 Phillips screwdriver for mounting the optional antenna
18 AWG (0.75 mm²) and 22 AWG (0.34 mm²) wire for possible cable extensions
Relay with a coil current of 60 mA (may be needed when installing on an ignition wire) (Connections for Vessels Without an Existing Kill Switch)
Parent Topic: Important Safety Information
