Adjusting the Backlight Select Settings > System > Display > Backlight. Adjust the backlight. TIP: From any screen, press repeatedly to scroll through the brightness levels. This can be helpful when the brightness is so low you cannot see the screen. Parent Topic: Customizing the RV Fixed Display DeviceHomeCustomizing the RV Fixed Display DeviceAdjusting the Backlight
