Customizing the Startup Screen
You can personalize the image that is displayed while the device is turning on. For the best fit, the image should be 50 MB or less and conform to the recommended dimensions (Recommended Startup Image Dimensions).
- Insert a memory card that contains the image you want to use.
- Select .
- Select the memory card slot.
- Select the image.
- Select Set as Startup Image.
The new image is shown when turning on the device.
Parent Topic: Customizing the RV Fixed Display Device
