Specifications
Specification |
Measurement |
Temperature range |
From -15° to 55°C (from 5° to 131°F) |
Input voltage |
From 10 to 32 Vdc |
Fuse |
6 A, 125 V fast-acting |
Memory card |
2 SD® card slots; 32 GB max. card size |
Wireless frequency |
2.4 GHz @ 17.6 dBm |
Specification |
Measurement |
Dimensions (W × H × D) |
224 × 142.5 × 53.9 mm (8 13/16 × 5 5/8 × 2 1/8 in.) |
Display size (W × H) |
154 × 86 mm (6.1 × 3.4 in.) |
Weight |
0.86 kg (1.9 lb.) |
Max. power usage at 10 Vdc |
24 W |
Typical current draw at 12 Vdc |
1.5 A |
Max. current draw at 12 Vdc |
2.0 A |
Specification |
Measurement |
256.4 × 162.3 × 52.5 mm (10 1/8 × 6 3/8 × 2 1/16 in.) |
197 × 114 mm (7.74 × 4.49 in.) |
Weight |
1.14 kg (2.5 lb.) |
27 W |
1.3 A |
2.3 A |
