Restoring the Original Device Factory Settings
NOTE:
This affects all devices on the network.
- Select .
Select an option:
To reset the device settings to the factory default values, select Reset Default Settings. This restores the default configuration settings, but does not remove saved user data or software updates.
To clear saved data, select Delete User Data. This does not affect software updates.
To clear saved data and reset device settings to the factory default values, disconnect the device from the Garmin® Marine Network, and select Delete Data and Reset Settings. This does not affect software updates.
Parent Topic: Device Configuration
