Single-Ended NMEA 0183 Device Connections
Wiring diagram with callouts
Item
Description
Callout number 1
Power source
Callout number 2
Power/NMEA® 0183 cable
Callout number 3
NMEA 0183 device
Item
Garmin® Wire Function
Garmin Wire Color
NMEA 0183 Device Wire Function
Callout number 1
Power
Red
Power
Callout number 2
Power ground
Black
Power ground
Callout number 3
RXB
Violet
Not applicable
Callout number 4
RXA
Brown
TX
Callout number 5
TXA
Blue
RX
Callout number 6
TXB
Gray
N/A
  • If the NMEA 0183 device has only one input (receive, RX) wire (no A, B, +, or -), you must leave the TXB wire unconnected.
  • If the NMEA 0183 device has only one output (transmit, TX) wire (no A, B, +, or -), you must connect the RXB wire to ground.
GUID-7AA5B76A-FA51-4893-BD66-64487F22275B v7
January 2025
