Data Fields
Some data fields require you to be navigating to display data. Not all data fields are available for all models.
ACTIVITY DIST.
The distance traveled for the current track or activity.
ALT LOCATION
The position of your alternate location. You must be navigating for this data to appear.
AVERAGE LAP
The average lap time for the current activity.
BATTERY
The remaining battery power.
BATT GAIN TDY
The battery power gained since midnight.
BEARING
The direction from your current location to a destination. You must be navigating for this data to appear.
COMPASS HDG
The direction you are moving based on the compass.
COURSE
The direction from your starting location to a destination. Course can be viewed as a planned or set route. You must be navigating for this data to appear.
CURRENT LAP
The stopwatch time for the current lap.
DATE
The current day, month, and year.
DESTINATION
The last point on the route or course. You must be navigating for this data to appear.
DEST LOCATION
The position of your final destination. You must be navigating for this data to appear.
DIST TO DEST
The remaining distance to the final destination. You must be navigating for this data to appear.
DIST TO NEXT
The remaining distance to the next waypoint on the route. You must be navigating for this data to appear.
ELAP ACT TIME
The total time recorded. For example, if you start the timer and run for 10 minutes, then stop the timer for 5 minutes, then start the timer and run for 20 minutes, your elapsed time is 35 minutes.
ELEVATION
The altitude of your current location above or below sea level.
ETA AT DEST
The estimated time of day when you will reach the final destination (adjusted to the local time of the destination). You must be navigating for this data to appear.
ETA AT NEXT
The estimated time of day when you will reach the next waypoint on the route (adjusted to the local time of the waypoint). You must be navigating for this data to appear.
GLIDE RATIO
The ratio of horizontal distance traveled to the change in vertical distance.
GPS
The strength of the GPS satellite signal.
GPS ACCURACY
The margin of error for your exact location. For example, your GPS location is accurate to within +/- 3.65 m (12 ft.).
GPS HEADING
The direction you are moving based on GPS.
GRADE
The calculation of rise (elevation) over run (distance). For example, if you climb 3 m (10 ft.) for every 60 m (200 ft.) you travel, the grade is 5%.
GR TO DEST
The glide ratio required to descend from your current position to the destination elevation. You must be navigating for this data to appear.
HEADING
The direction you are moving.
LAPS
The number of laps completed for the current activity.
LAST LAP TIME
The stopwatch time for the last completed lap.
LOCATION
The current position in latitude and longitude, regardless of the selected position format setting.
MAX SPEED
The top speed for the current activity.
MOVING AVG
The average speed while moving for the current activity.
MOVING TIME
The total time spent moving for the current activity.
NEXT POINT
The next point on the route. You must be navigating for this data to appear.
NONE
This is a blank data field.
ODOMETER
A running tally of the distance traveled for all trips. This total does not clear when resetting the trip data.
OFF COURSE
The distance to the left or right by which you have strayed from the original path of travel. You must be navigating for this data to appear.
OVERALL AVG
The average speed while moving and stopped since the last reset.
POINTER
An arrow points in the direction of the next waypoint or turn. You must be navigating for this data to appear.
SOLAR INT
The intensity of solar input.
SPEED
The current rate of travel.
STOPPED TIME
The total time stopped for the current activity.
STOPWATCH
The stopwatch time for the current activity.
SUNRISE
The time of sunrise based on your GPS position.
SUNRISE/SET
The time of the next sunrise or sunset based on your GPS position.
SUNSET
The time of sunset based on your GPS position.
TIME OF DAY
The time of day based on your current location and time settings (format, time zone, daylight saving time).
TIME TO DEST
The estimated time remaining before you reach the destination. You must be navigating for this data to appear.
TIME TO NEXT
The estimated time remaining before you reach the next waypoint in the route. You must be navigating for this data to appear.
TO COURSE
The direction in which you must move to get back on the route. You must be navigating for this data to appear.
TOTAL LAP
The stopwatch time for all the completed laps.
TRIP ODOMETER
A running tally of the distance traveled since the last reset.
TRIP TIME
A running tally of the total time spent moving and not moving since the last reset.
TURN
The angle of difference (in degrees) between the bearing to your destination and your current course. L means turn left. R means turn right. You must be navigating for this data to appear.
V DIST TO DEST
The elevation distance between your current position and the final destination. You must be navigating for this data to appear.
V DIST TO NEXT
The elevation distance between your current position and the next waypoint in the route. You must be navigating for this data to appear.
VEL MADE GOOD
The speed at which you are closing on a destination along a route. You must be navigating for this data to appear.
VERTICAL SPEED
The rate of ascent or descent over time.
VS TO DEST
The rate of ascent or descent to a predetermined altitude. You must be navigating for this data to appear.
GUID-76DD39C5-047F-4599-892F-60C9207A6637 v5
April 2026
