Solar Charging While the Device is Turned Off
  1. Place your device in a sunny location.
  2. Hold Power to open the power menu.
  3. Select Power Off.
    The device goes into a low power, battery charging mode, and a screen with solar charging statistics appears. The display turns off automatically when sunlight is no longer detected.
    NOTE: You can enable or disable the solar charging screen in the system settings (System Settings).
GUID-76DD39C5-047F-4599-892F-60C9207A6637 v5
April 2026
