Settings
Changing the Units of Measure
  1. Select SETTINGS > UNITS.
  2. Select a unit of measure, and press OK.
Changing the Display Color
  1. Select an option:
    • To change the display color during a session, press OK, and select DISPLAY COLOR.
    • To change the display color outside of a session, select SETTINGS > DISPLAY COLOR.
  2. Press OK to cycle through the color options.
Changing the Backlight Brightness
    • To change the backlight brightness during a session, press OK, and select BACKLIGHT.
    • To change the backlight brightness outside of a session, select SETTINGS > BACKLIGHT.
  2. Press OK to cycle through the brightness levels.
Changing the Backlight Timeout
The backlight timeout setting sets how long the screen backlight stays on after a period of inactivity.
    • To change the backlight timeout during a session, press OK, and select BACKLIGHT TIMEOUT.
    • To change the backlight timeout outside of a session, select SETTINGS > BACKLIGHT TIMEOUT.
  2. Press OK to cycle through the time intervals.
Pro Settings
Select SETTINGS > PRO SETTINGS.
PROJECTILE WEIGHT ENTRY
Enables or disables the projectile weight entry screen before each session. You can use the projectile weight to calculate the kinetic energy and power factor of your projectile.
SHOW ALIGNMENT DIAGRAMS
Enables or disables the alignment diagrams that appear before each session.
NOTE: An alignment diagram appears the first time you use a new mode even after you disable alignment diagrams.
DOWNRANGE MODE
WARNING
When placing or adjusting the device in downrange mode, remain aware of your surroundings and follow any applicable safety protocols associated with the area in which you are shooting. Failure to do so could cause property damage, serious personal injury, or death.
NOTICE
Use of this device in downrange mode could result in possible property damage due to your shooting activities or the shooting activities of others. Garmin® claims no responsibility for and does not warranty such property damage.
Sets the screen to flash five times after the chronograph detects a shot. This can be useful to improve visibility of when a shot is detected when using the device to track velocity downrange.
Changing the Device Language
  1. Select SETTINGS > LANGUAGE.
  2. Select a language.
Resetting Data and Settings
The chronograph offers options for deleting your user data and resetting all settings to the factory default values.
NOTE: If you clear data from the chronograph after you sync with the ShotView™ app, the data will not be deleted from the app.
  1. Select SETTINGS > RESET.
  2. Select an option:
    • To delete all of your recorded sessions from the chronograph, select CLEAR ALL SESSIONS.
    • To reset all settings to default values, select RESET ALL SETTINGS.
    • To reset all settings to factory default values and delete all user data and sessions, select FACTORY RESET.
  3. Select YES.
GUID-76BF3BAE-91A9-4BF6-9196-26F824CA8CAD v4
April 2025
