Charging the Dog Collar Device
NOTICE
To prevent corrosion, thoroughly dry the contacts on the dog collar device and the surrounding area before connecting the charging clip.
You should fully charge the battery before you use the dog collar device for the first time. Charging a fully depleted battery takes about five hours.
  1. Snap the charging clip 1 onto the dog collar device 2.
    Connecting the charger to the dog collar device with callouts
  2. Plug the small end of the power cable into the USB port on the charging clip.
  3. Plug the power cable into a power source.
    The status LED is solid red when the collar is charging.
  4. After the status LED turns solid green, remove the charging clip from the collar.
GUID-74035D64-33C8-4CC0-8053-23CB54692716 v3
January 2026
