Enabling / Disabling Automatic North Up Orientation:
The map can be configured to switch automatically to a north up orientation when the map range reaches a designated range or when the aircraft is on the ground.
  1. Navigate to the Map Settings window > General Tab.
  2. Touch the North Up on Ground Indicator Button to enable the map to automatically orient North while on the ground.
    Or:
    Touch the North Up Above Indicator Button to enable the map to automatically orient North when the zoom level is above the designated distance.
190-03123-01 Rev B
July 2026
