Vne Adjusted for True Airspeed (Optional)
The airspeed indicator can optionally be configured to display Vne adjusted for true airspeed and allow the pilot of the aircraft to maintain situational awareness of the TAS Vne. This is useful in aircraft where true airspeed (instead of indicated airspeed) must be kept below Vne. When accounting for altitude and temperature, the TAS of the aircraft may be greater than the indicated airspeed. If configured, the AXIS™ flight displays can calculate and display this reduction in Vne. As TAS increases with the altitude and temperature calculations, a solid red band is displayed between the TAS adjusted Vne and the actual indicated value for Vne.
47: Vne Adjusted for True Airspeed
190-03123-01 Rev B
July 2026
