Activating the Flight Director
An initial press of a key listed in the table below (when the flight director is not active) activates the flight director in the listed modes. The flight director may be turned off and the Command Bars removed from the display by pressing the FD Key again. The FD Key is disabled when the autopilot is engaged.
Table 50: Flight Director Activation (GMC 507)
Control Pressed
Lateral Modes Activated
Vertical Modes Activated
FD Key
Roll Hold (default)
ROL
Pitch Hold (default)
PIT
AP Key
Roll Hold (default)
ROL
PIT
TO/GA Button
Takeoff (on ground)
Go Around (in air)
TO
GA
Takeoff (on ground)
Go Around (in air)
TO
GA
ALT Key
Roll Hold (default)
ROL
Altitude Hold
ALT
VS Key
Roll Hold (default)
ROL
Vertical Speed
VS
VNAV Key
Roll Hold (default)
ROL
Vertical Navigation1
VNAV
IAS Key
Roll Hold (default)
ROL
Indicated Airspeed
IAS
APR Key
Approach2
GPS
VOR
LOC
PIT
NAV Key
Navigation2
GPS
VOR
LOC
BC
PIT
HDG Key
Heading Select
HDG
PIT
TRK Key
Track Select
TRK
PIT
LVL Key
Level Hold
LVL
Level Hold
LVL
1 Valid VNAV flight plan must be entered before VNAV Key press activates flight director.
2 The selected navigation receiver must have a valid VOR or LOC signal or active GPS course before NAV or APR Key press activates flight director.
190-03123-01 Rev B
July 2026
