Chart Selection
When a flight plan is active, or when flying direct-to a destination, the initial set of charts made available pertain to the departure airport. After departing the airport environment, the initial chart set made available pertains to the destination airport. When no flight plan is active, or when not flying to a direct-to destination, the initial chart set is made available for the nearest airport. If the charts pane is displayed when landing, the chart will automatically change to the airport diagram upon landing.
The aircraft symbol is shown on the chart only if the chart is to scale and the aircraft position is within the boundaries of the chart.
When no terminal procedure chart is available for the nearest airport or the selected airport, the banner 'No Available Charts' appears on the screen. The 'No Available Charts' banner does not refer to the Jeppesen or AeroNav Services Terminal Procedures Charts subscription, but rather the availability of a particular airport chart selection or procedure for a selected airport.
If there is a problem in rendering the data (e.g., a data error or a failure of an individual chart), the banner 'Unable To Display Chart' is then displayed.
190-03123-01 Rev B
July 2026
