Data Fields
NOTE: Not all data fields are available for all activity types. Some data fields require ANT‍+® or Bluetooth® accessories to display data. Some data fields appear in more than one category on the watch.
TIP: You can also customize the data fields from the watch settings in the Garmin Connect™ app.
Cadence Fields
Name
Description
Average Cadence
Cycling. The average cadence for the current activity.
Average Cadence
Running. The average cadence for the current activity.
Cadence
Cycling. The number of revolutions of the crank arm. Your device must be connected to a cadence accessory for this data to appear.
Cadence
Running. The steps per minute (right and left).
Lap Cadence
Cycling. The average cadence for the current lap.
Lap Cadence
Running. The average cadence for the current lap.
Last Lap Cadence
Cycling. The average cadence for the last completed lap.
Last Lap Cadence
Running. The average cadence for the last completed lap.
Charts
Name
Description
Barometer Chart
A chart showing the barometric pressure over time.
Elevation Chart
A chart showing the elevation over time.
Heart Rate Chart
A chart showing your heart rate throughout the activity.
Pace Chart
A chart showing your pace throughout the activity.
Power Chart
A chart showing your power throughout the activity.
Speed Chart
A chart showing your speed throughout the activity.
Compass Fields
Name
Description
Compass Heading
The direction you are moving based on the compass.
GPS Heading
The direction you are moving based on GPS.
Heading
The direction you are moving.
Distance Fields
Name
Description
Distance
The distance traveled for the current track or activity.
Int. Distance
The distance traveled for the current interval.
Lap Distance
The distance traveled for the current lap.
Last Lap Distance
The distance traveled for the last completed lap.
Nautical Distance
The distance traveled in nautical meters or nautical feet.
Diving Fields
Name
Description
Ascent Rate
The current rate of ascent toward the surface.
CNS
Your current central nervous system oxygen toxicity percentage.
Current Gas PO2
The partial pressure of oxygen (PO2) of the diluent gas during a closed-circuit rebreather (CCR) dive.
Dive Number
The number of dives you have completed.
Last Dive Depth
The maximum depth achieved during the last dive.
Last Dive Time
The amount of time you spent below the surface during the last dive.
Maximum Depth
The maximum depth descended during a dive.
OTU
Your current oxygen toxicity units.
Surface Time
The amount of time elapsed since surfacing from a dive.
Time to Surface
The amount of time required to safely ascend to the surface.
Elevation Fields
Name
Description
Average Ascent
The average vertical distance of ascent since the last reset.
Average Descent
The average vertical distance of descent since the last reset.
Elevation
The altitude of your current location above or below sea level.
Glide Ratio
The ratio of horizontal distance traveled to the change in vertical distance.
GPS Elevation
The altitude of your current location using GPS.
Grade
The calculation of rise (elevation) over run (distance). For example, if for every 3 m (10 ft.) you climb you travel 60 m (200 ft.), the grade is 5%.
Lap Ascent
The vertical distance of ascent for the current lap.
Lap Descent
The vertical distance of descent for the current lap.
Last Lap Ascent
The vertical distance of ascent for the last completed lap.
Last Lap Descent
The vertical distance of descent for the last completed lap.
Maximum Ascent
The maximum rate of ascent in feet per minute or meters per minute since the last reset.
Maximum Descent
The maximum rate of descent in meters per minute or feet per minute since the last reset.
Maximum Elevation
The highest elevation reached since the last reset.
Minimum Elevation
The lowest elevation reached since the last reset.
Total Ascent
The total elevation distance ascended since the last reset.
Total Descent
The total elevation distance descended since the last reset.
Floors Fields
Name
Description
Floors Climbed
The total number of floors climbed up for the day.
Floors Descended
The total number of floors climbed down for the day.
Floors per Minute
The number of floors climbed up per minute.
Force Fields
Name
Description
3s Force
The 3-second moving average of force applied to the pedal platforms, in Newtons.
10s Force
The 10-second moving average of force applied to the pedal platforms, in Newtons.
30s Force
The 30-second moving average of force applied to the pedal platforms, in Newtons.
Avg Force
The average force applied to the pedal platforms during the activity, in Newtons.
Force
The force applied to the pedal platforms, in Newtons.
Lap Force
The average force applied to the pedal platforms during the current lap, in Newtons.
Lap Norm. Force
The normalized force applied to the pedal platforms during the current lap, in Newtons.
Last Lap Force
The average force applied to the pedal platforms during the previous lap, in Newtons.
Last Lap Norm. Force
The normalized force applied to the pedal platforms during the previous lap, in Newtons.
Max. Force
The maximum force applied to the pedal platforms during the activity, in Newtons.
Max. Lap Force
The maximum force applied to the pedal platforms during the current lap, in Newtons.
Normalized Force
The normalized force applied to the pedal platforms, in Newtons.
Gears
Name
Description
Di2 Battery
The remaining battery power of a Di2 sensor.
Front
The front bike gear from a gear position sensor.
Gear Battery
The battery status of a gear position sensor.
Gear Combo
The current gear combination from a gear position sensor.
Gears
The front and rear bike gears from a gear position sensor.
Gear Ratio
The number of teeth on the front and rear bike gears, as detected by a gear position sensor.
Rear
The rear bike gear from a gear position sensor.
Graphical
Name
Description
Cadence Gauge
Running. A color gauge showing your current cadence range.
Compass Gauge
GCT Balance Gauge
A color gauge showing the left/right balance of ground contact time while running.
Ground Contact Time Gauge
A color gauge showing the amount of time in each step that you spend on the ground while running, measured in milliseconds.
Heart Rate Gauge
A color gauge showing your current heart rate zone.
Heart Rate Zones Ratio
A color gauge showing the ratio of time spent in each heart rate zone.
PacePro Gauge
Running. Your current split pace and your target split pace.
Power Gauge
A color gauge showing your current power zone.
Stamina Gauge (Dist.)
A gauge showing your current stamina distance remaining.
Stamina Gauge (Time)
A gauge showing your current stamina time remaining.
Step Speed Loss Gauge
A color gauge showing your current step speed loss while running.
Step Speed Loss % Gauge
A color gauge showing your average step speed loss percent.
Total Ascent/Descent Gauge
The total elevation distances ascended and descended during the activity or since the last reset.
Training Effect Gauge
The impact of the current activity on your aerobic and anaerobic fitness levels.
Vertical Oscillation Gauge
A color gauge showing the amount of bounce while you are running.
Vertical Ratio Gauge
A color gauge showing the ratio of vertical oscillation to stride length.
Heart Rate Fields
Name
Description
% Heart Rate Reserve
The percentage of heart rate reserve (maximum heart rate minus resting heart rate).
Aerobic Training Effect
The impact of the current activity on your aerobic fitness level.
Anaerobic Training Effect
The impact of the current activity on your anaerobic fitness level.
Avg. %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current activity.
Average HR
The average heart rate for the current activity.
Avg. HR %Max.
The average percentage of maximum heart rate for the current activity.
Heart Rate
Your heart rate in beats per minute (bpm). Your device must have wrist-based heart rate or be connected to a compatible heart rate monitor.
HR %Max.
The percentage of maximum heart rate.
HR Zone
The current range of your heart rate (1 to 5). The default zones are based on your user profile and maximum heart rate (220 minus your age).
Int. Avg. %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current swim interval.
Int. Avg. %Max.
The average percentage of maximum heart rate for the current swim interval.
Int. Avg. HR
The average heart rate for the current swim interval.
Int. Max. %HRR
The maximum percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current swim interval.
Int. Max. %Max.
The maximum percentage of maximum heart rate for the current swim interval.
Int. Max. HR
The maximum heart rate for the current swim interval.
Lap %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current lap.
Lap HR
The average heart rate for the current lap.
Lap HR %Max.
The average percentage of maximum heart rate for the current lap.
Last Lap %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the last completed lap.
Last Lap HR
The average heart rate for the last completed lap.
L. Lap HR %Max.
The average percentage of maximum heart rate for the last completed lap.
Time in Zone
The time elapsed in each heart rate zone.
Lengths Fields
Name
Description
Interval Lengths
The number of pool lengths completed during the current interval.
Lengths
The number of pool lengths completed during the current activity.
Navigation Fields
Name
Description
Bearing
The direction from your current location to a destination. You must be navigating for this data to appear.
Course
The direction from your starting location to a destination. Course can be viewed as a planned or set route. You must be navigating for this data to appear.
Destination Location
The position of your final destination.
Destination Waypoint
The last point on the route to the destination. You must be navigating for this data to appear.
Distance Remaining
The remaining distance to the final destination. You must be navigating for this data to appear.
Distance To Next
The remaining distance to the next waypoint on the route. You must be navigating for this data to appear.
Estimated Total Distance
The estimated distance from the start to the final destination. You must be navigating for this data to appear.
ETA at Next
The estimated time of day when you will reach the next waypoint on the route (adjusted to the local time of the waypoint). You must be navigating for this data to appear.
ETA
The estimated time of day when you will reach the final destination (adjusted to the local time of the destination). You must be navigating for this data to appear.
ETE
The estimated time remaining until you reach the final destination. You must be navigating for this data to appear.
Glide Ratio to Destination
The glide ratio required to descend from your current position to the destination elevation. You must be navigating for this data to appear.
Lat/Lon
The current position in latitude and longitude regardless of the selected position format setting.
Location
The current position using the selected position format setting.
Next Fork
The distance to the next fork on a trail based on the NextFork™ map guide.
Next Waypoint
The next point on the route. You must be navigating for this data to appear.
Off Course
The distance to the left or right by which you have strayed from the original path of travel. You must be navigating for this data to appear.
Time to Next
The estimated time remaining before you reach the next waypoint in the route. You must be navigating for this data to appear.
Velocity Made Good
The speed at which you are closing on a destination along a route. You must be navigating for this data to appear.
Vertical Dist. to Dest.
The elevation distance between your current position and the final destination. You must be navigating for this data to appear.
Vertical Speed to Target
The rate of ascent or descent to a predetermined altitude. You must be navigating for this data to appear.
Other Fields
Name
Description
Active Calories
The calories burned during the activity.
Ambient Pressure
The uncalibrated environmental pressure.
Barometric Pressure
The current calibrated environmental pressure.
Battery Hours
The number of hours remaining before the battery power is depleted.
Battery Level
The remaining battery power.
COG
The actual direction of travel, regardless of the course steered and temporary variations in heading.
Distance to Start Line
The remaining distance to the race starting line. You must be navigating for this data to appear.
eBike Battery
The remaining battery power of an ebike.
eBike Range
The estimated remaining distance the ebike can provide assistance.
Flow
The measurement of how consistently you maintain speed and smoothness through turns in the current activity.
GPS
The strength of the GPS satellite signal.
Grit
The measurement of difficulty for the current activity based on elevation, gradient, and rapid changes in direction.
Intervals
The number of intervals completed for the current activity.
Lap Flow
The overall flow score for the current lap.
Lap Grit
The overall grit score for the current lap.
Laps
The number of laps completed for the current activity.
Last Round Reps
The number of repetitions in the last round of the activity.
Lift
The angle of lift during a sailing activity.
Load
The training load for the current activity. Training load is the amount of excess post-exercise oxygen consumption (EPOC), which indicates the strenuousness of your workout.
LTE
The strength of the LTE signal.
Performance Condition
The performance condition score is a real-time assessment of your ability to perform.
Reps
During a gym activity, the number of repetitions in a workout set.
Respiration Rate
Your respiration rate in breaths per minute (brpm).
Rounds
The number of exercise groups performed in an activity, such as jump rope.
Solar Accumulation
The amount of solar energy accumulated in lux-hours.
Solar Intensity
The current solar intensity shown as a percent of 50,000 lux.
Steps
The number of steps taken during the current activity.
Stress
Your current stress level.
Sunrise
The time of sunrise based on your GPS position.
Sunset
The time of sunset based on your GPS position.
Tack Assist
A gauge to help you determine if your boat is being lifted or headed.
Time of Day
The time of day based on your current location and time settings (format, time zone, daylight saving time).
Total Calories
The amount of total calories burned for the day.
Pace Fields
Name
Description
500m Pace
The current pace per 500 meters.
Average 500m Pace
The average pace per 500 meters for the current activity.
Average Pace
The average pace for the current activity.
Grade Adjusted Pace
The average pace adjusted by the steepness of the terrain.
Int. Pace
The average pace for the current interval.
Lap 500m Pace
The average pace per 500 meters for the current lap.
Lap Pace
The average pace for the current lap.
Last Lap 500m Pace
The average pace per 500 meters for the last lap.
Last Lap Pace
The average pace for the last completed lap.
Last Len. Pace
The average pace for your last completed pool length.
Pace
The current pace.
Rolling Pace
The average pace of the last completed mile or kilometer.
PacePro Fields
Name
Description
Next Split Distance
Running. The total distance of the next split.
Next Split Target Pace
Running. The target pace for the next split.
Split Distance
Running. The total distance of the current split.
Split Distance Remaining
Running. The remaining distance of the current split.
Split Pace
Running. The pace for the current split.
Split Target Pace
Running. The target pace for the current split.
Power Fields
Name
Description
% FTP
The current power output as a percentage of functional threshold power.
3s Avg. Balance
The 3-second moving average of the left/right power balance.
3s Power
The 3-second moving average of power output.
3s Power to Weight
The 3-second average power measured in watts per kilogram for the current activity.
10s Avg. Balance
The 10-second moving average of the left/right power balance.
10s Power
The 10-second moving average of power output.
10s Power to Weight
The 10-second average power measured in watts per kilogram for the current activity.
30s Avg. Balance
The 30-second moving average of the left/right power balance.
30s Power
The 30-second moving average of power output.
30s Power to Weight
The 30-second average power measured in watts per kilogram for the current activity.
Avg. Balance
The average left/right power balance for the current activity.
Average Left PP
The average power phase angle for the left leg for the current activity.
Avg. Power
The average power output for the current activity.
Avg. Right PP
The average power phase angle for the right leg for the current activity.
Avg. Left PPP
The average power phase peak angle for the left leg for the current activity.
Avg. PCO
The average platform center offset for the current activity.
Avg. Power to Weight
The average power measured in watts per kilogram for the current activity.
Avg. Right PPP
The average power phase peak angle for the right leg for the current activity.
Balance
The current left/right power balance.
Intensity Factor
The Intensity Factor™ for the current activity.
Lap Balance
The average left/right power balance for the current lap.
Lap Left PPP
The average power phase peak angle for the left leg for the current lap.
Lap Left PP
The average power phase angle for the left leg for the current lap.
Lap Max. Power
The top power output for the current lap.
Lap NP
The average Normalized Power™ for the current lap.
Lap PCO
The average platform center offset for the current lap.
Lap Power
The average power output for the current lap.
Lap Power to Weight
The average power measured in watts per kilogram for the current lap.
Lap Right PPP
The average power phase peak angle for the right leg for the current lap.
Lap Right PP
The average power phase angle for the right leg for the current lap.
Last Lap Max. Power
The top power output for the last completed lap.
Last Lap NP
The average Normalized Power for the last completed lap.
Last Lap Power
The average power output for the last completed lap.
Left PPP
The current power phase peak angle for the left leg. Power phase peak is the angle range over which the rider produces the peak portion of the driving force.
Left PP
The current power phase angle for the left leg. Power phase is the pedal stroke region where positive power is produced.
Max. Power
The top power output for the current activity.
NP
The Normalized Power for the current activity.
Pedal Smooth.
The measurement of how evenly a rider is applying force to the pedals throughout each pedal stroke.
PCO
The platform center offset. Platform center offset is the location on the pedal platform where force is applied.
Power
The current power output in watts. For skiing activities, your device must be connected to a compatible heart rate monitor.
Power to Weight
The current power measured in watts per kilogram.
Power Zone
The current range of power output based on your FTP or custom settings.
Right PPP
The current power phase peak angle for the right leg. Power phase peak is the angle range over which the rider produces the peak portion of the driving force.
Right PP
The current power phase angle for the right leg. Power phase is the pedal stroke region where positive power is produced.
Time in Zone
The time elapsed in each power zone.
Time Seat.
The time spent seated while pedaling for the current activity.
Time Seat. Lap
The time spent seated while pedaling for the current lap.
Time Stand.
The time spent standing while pedaling for the current activity.
Time Stand. Lap
The time spent standing while pedaling for the current lap.
TSS
The Training Stress Score™ for the current activity.
Torque Eff.
The measurement of how efficiently a rider is pedaling.
Work
The accumulated work performed (power output) in kilojoules.
Rest Fields
Name
Description
Repeat On
The timer for the last interval plus the current rest (pool swimming).
Rest Timer
The timer for the current rest (pool swimming).
Run Dynamics
Name
Description
Average GCT Balance
The average ground contact time balance for the current session.
Average Ground Contact Time
The average amount of ground contact time for the current activity.
Average Step Speed Loss
The average measure of step speed loss for the current activity.
Avg. Step Speed Loss Percent
The average ratio of step speed loss over speed for the current activity.
Average Stride Length
The average stride length for the current session.
Average Vertical Oscillation
The average amount of vertical oscillation for the current activity.
Average Vertical Ratio
The average ratio of vertical oscillation to stride length for the current session.
GCT Balance
The left/right balance of ground contact time while running.
Ground Contact Time
The amount of time in each step that you spend on the ground while running, measured in milliseconds. Ground contact time is not calculated while walking.
Lap GCT Balance
The average ground contact time balance for the current lap.
Lap Ground Contact Time
The average amount of ground contact time for the current lap.
Lap Step Speed Loss
The average step speed loss for the current lap.
Lap Step Speed Loss Percent
The average ratio of step speed loss over speed for the current lap.
Lap Stride Length
The average stride length for the current lap.
Lap Vertical Oscillation
The average amount of vertical oscillation for the current lap.
Lap Vertical Ratio
The average ratio of vertical oscillation to stride length for the current lap.
Step Speed Loss
The measure of step speed loss in centimeters per second while running.
The ratio of step speed loss over speed while running.
Stride Length
The length of your stride from one footfall to the next, measured in meters.
The amount of bounce while you are running. The vertical motion of your torso, measured in centimeters for each step.
Vertical Ratio
The ratio of vertical oscillation to stride length.
Speed Fields
Name
Description
Avg. Moving Speed
The average speed when moving for the current activity.
Avg. Overall Speed
The average speed for the current activity, including both moving and stopped speeds.
Average Speed
The average speed for the current activity.
Avg. SOG
The average speed of travel for the current activity, regardless of the course steered and temporary variations in heading.
Lap SOG
The average speed of travel for the current lap, regardless of the course steered and temporary variations in heading.
Lap Speed
The average speed for the current lap.
Last Lap SOG
The average speed of travel for the last completed lap, regardless of the course steered and temporary variations in heading.
Last Lap Speed
The average speed for the last completed lap.
Max. SOG
The maximum speed of travel for the current activity, regardless of the course steered and temporary variations in heading.
Maximum Speed
The top speed for the current activity.
Speed
The current rate of travel.
SOG
The actual speed of travel, regardless of the course steered and temporary variations in heading.
Vertical Speed
The rate of ascent or descent over time.
Stamina Fields
Name
Description
Stamina
The current remaining stamina.
Distance Remaining
The current stamina distance remaining at the current effort.
Stamina Potential
The remaining potential stamina.
Time Remaining
The current stamina time remaining at the current effort.
Stroke Fields
Name
Description
Average Distance Per Stroke
Indoor cross-country skiing. The average distance traveled per stroke during the current activity.
Swimming. The average distance traveled per stroke during the current activity.
Paddle sports. The average distance traveled per stroke during the current activity.
Average Stroke Rate
Indoor cross-country skiing. The average number of strokes per minute (spm) during the current activity.
Average Stroke Rate
Paddle sports. The average number of strokes per minute (spm) during the current activity.
Average Strokes Per Length
The average number of strokes per pool length during the current activity.
Distance Per Stroke
Indoor cross-country skiing. The distance traveled per stroke.
Distance Per Stroke
Paddle sports. The distance traveled per stroke.
Interval Strokes Per Length
The average number of strokes per pool length during the current interval.
Interval Stroke Type
The current stroke type for the interval.
Lap Distance Per Stroke
Indoor cross-country skiing. The average distance traveled per stroke during the current lap.
Swimming. The average distance traveled per stroke during the current lap.
Paddle sports. The average distance traveled per stroke during the current lap.
Lap Stroke Rate
Indoor cross-country skiing. The average number of strokes per minute (spm) during the current lap.
Lap Stroke Rate
Swimming. The average number of strokes per minute (spm) during the current lap.
Lap Stroke Rate
Paddle sports. The average number of strokes per minute (spm) during the current lap.
Lap Strokes
Indoor cross-country skiing. The total number of strokes for the current lap.
Lap Strokes
Swimming. The total number of strokes for the current lap.
Lap Strokes
Paddle sports. The total number of strokes for the current lap.
Last Lap Distance Per Stroke
Indoor cross-country skiing. The average distance traveled per stroke during the last completed lap.
Swimming. The average distance traveled per stroke during the last completed lap.
Paddle sports. The average distance traveled per stroke during the last completed lap.
Last Lap Stroke Rate
Indoor cross-country skiing. The average number of strokes per minute (spm) during the last completed lap.
Swimming. The average number of strokes per minute (spm) during the last completed lap.
Paddle sports. The average number of strokes per minute (spm) during the last completed lap.
Last Lap Strokes
Indoor cross-country skiing. The total number of strokes for the last completed lap.
Last Lap Strokes
Swimming. The total number of strokes for the last completed lap.
Last Lap Strokes
Paddle sports. The total number of strokes for the last completed lap.
Last Length Strokes
The total number of strokes for the last completed pool length.
Last Length Stroke Type
The stroke type used during the last completed pool length.
Stroke Rate
Indoor cross-country skiing. The number of strokes per minute (spm).
Stroke Rate
Swimming. The number of strokes per minute (spm).
Stroke Rate
Paddle sports. The number of strokes per minute (spm).
Strokes
Indoor cross-country skiing. The total number of strokes for the current activity.
Strokes
Swimming. The total number of strokes for the current activity.
Strokes
Paddle sports. The total number of strokes for the current activity.
Swolf Fields
Name
Description
Average Swolf
The average swolf score for the current activity. Your swolf score is the sum of the time for one length plus the number of strokes for that length (Swim Terminology). In open water swimming, 25 meters is used to calculate your swolf score.
Interval Swolf
The average swolf score for the current interval.
Lap Swolf
The swolf score for the current lap.
Last Lap Swolf
The swolf score for the last completed lap.
Last Length Swolf
The swolf score for the last completed pool length.
Temperature Fields
Name
Description
24-Hour Maximum
The maximum temperature recorded in the last 24 hours from a compatible temperature sensor.
24-Hour Minimum
The minimum temperature recorded in the last 24 hours from a compatible temperature sensor.
Avg Temperature
The average temperature during the activity.
Max Temperature
The maximum temperature during the activity.
Min Temperature
The minimum temperature during the activity.
Temperature
The temperature of the air. Your body temperature affects the temperature sensor. You can pair a tempe™ sensor with your device to provide a consistent source of accurate temperature data.
Timer Fields
Name
Description
Average Lap Time
The average lap time for the current activity.
Average Move Time
The average move time for the current activity.
Average Pose Time
The average pose time for the current activity.
Elapsed Time
The total time recorded. For example, if you start the activity timer and run for 10 minutes, then stop the timer for 5 minutes, then start the timer and run for 20 minutes, your elapsed time is 35 minutes.
Estimated Finish Time
The estimated finish time of the current activity.
Interval Time
The stopwatch time for the current interval.
Lap Time
The stopwatch time for the current lap.
Last Lap Time
The stopwatch time for the last completed lap.
Last Move Time
The stopwatch time for the last completed move.
Last Pose Time
The stopwatch time for the last completed pose.
Move Time
The stopwatch time for the current move.
Moving Time
The total time moving for the current activity.
Overall Ahead/Behind
The overall time ahead or behind of the target pace or speed.
Pose Time
The stopwatch time for the current pose.
Race Timer
The time elapsed in the current sail race.
Set Timer
During a strength training activity, the amount of time spent in the current workout set.
Stopped Time
The total time stopped for the current activity.
Swim Time
The swimming time for the current activity, not including rest time.
Timer
The current time of the activity timer.
Workout Fields
Name
Description
Reps to Go
During a workout, the remaining repetitions.
Step Duration
The time or distance remaining for the workout step.
Step Pace
The current pace during the workout step.
Step Speed
The current speed during the workout step.
Step Time
The time elapsed for the workout step.
GUID-708A8F4D-9A78-49CF-9528-DE109BBCC472 v1
August 2026
