Customizing the Watch Face
You can customize the watch face information and appearance, or activate an installed Connect IQ™ watch face (Connect IQ Features).
  1. From the watch face, hold Middle-left button.
  2. Select Watch Face.
  3. Select an option:
    • To edit the watch face, select Edit.
    • To add and edit a new watch face, select Add New, select a category (fēnix® 9/9 Pro AMOLED only), and select Zoom in > Edit.
      NOTE: When you add a watch face, it appears in the favorites list. When you reach the maximum number of favorites, you must delete a watch face from the favorites list to add a new watch face.
  4. Select an option:
    NOTE: Not all options are available for all watch faces. Some watch faces have additional options, such as an alternate time zone or multiple styles.
    • To activate the watch face, select Apply.
    • To change the data that appears on the watch face, select Data, scroll and select a field to edit, then scroll and select an option.
    • To add or change an accent color for the watch face, select Accent Color, then scroll and select an option.
    • To change the color of the data that appears on the watch face, select Data Color, then scroll and select an option.
    • To change the background color, select Bkgd. Color, then scroll and select an option.
      NOTE: This feature is not available for fēnix 9/9 Pro AMOLED models.
    • To remove the watch face from your favorites list, select Delete.
GUID-708A8F4D-9A78-49CF-9528-DE109BBCC472 v1
August 2026
