Using Voice Commands
Select an option:
Hold
From the watch face, press
, and select Voice Command.
Hold
NOTE: You can customize the controls menu (Customizing the Controls Menu). - Say "OK Garmin".NOTE: You can enable the "OK Garmin" watch wake word in the system settings (Enabling a Wake Word for Your Watch).
- Say a voice command for the watch to perform (Watch Voice Commands).
The voice command system is designed to detect natural speech. This is a list of commonly used voice commands, but the watch does not require these exact phrases (other than OK Garmin). You can try saying variations of these commands in a way that is natural to you. Go to garmin.com/voicecommand/tips for voice command tips and troubleshooting information.
Voice Wake Word |
Function |
"OK Garmin" |
Wakes up the watch to listen for voice commands |
Voice Help Command |
Function |
What can I say? |
Shows a list of common voice commands |
Voice Command |
Function |
Find my phone |
Plays an audible alert on your paired phone, if it is within Bluetooth® range. |
Disable do not disturb |
Disables do not disturb mode to dim the screen and disable alerts and notifications. |
Turn on airplane mode |
Enables airplane mode to turn off all wireless communications. |
Increase brightness |
Raises the brightness level. |
Decrease brightness |
Lowers the brightness level. |
Set brightness to 80 |
Sets the brightness level to a specified percent. Available numbers are 0-100%. |
Voice Command |
Function |
Set a timer for fifteen minutes |
Sets a countdown timer for the specified time. |
Pause timer |
Pauses the currently running countdown timer. |
Resume timer |
Resumes the paused countdown timer. |
Cancel timer |
Cancels the currently running countdown timer. |
Start stopwatch |
Starts the stopwatch. |
Stop stopwatch |
Stops the stopwatch. |
Wake me up at 3:15 a.m. |
Sets a one-time alarm for the specified time. |
Voice Command |
Function |
Show me the weather |
Opens the weather app. |
Open the calendar |
Opens the calendar app. |
Start a run |
Starts a Run activity. |
Start hiking |
Starts a Hike activity. |
Open the triathlon app |
Starts a Triathlon activity. |
Voice Command |
Function |
Begin navigation |
Opens the Navigate menu to navigate to a destination. |
Save location |
Saves your current location. |
Switch to the compass app |
Opens the compass. |
Voice Command |
Function |
Change volume to 8 |
Adjusts the volume to the specified level. Available numbers are 0-10 or 0-100%. |
Increase volume |
Raises the audio volume. |
Decrease volume |
Lowers the audio volume. |
Play music |
Plays the currently selected media. |
Next song |
Plays the next media track. |
Previous song |
Plays the previous media track. |
Pause music |
Pauses the currently playing media. |
Mute |
Silences all audio. |
Unmute |
Unsilences all audio. |
