Viewing Measured Shots
Your device features automatic shot detection and recording. Each time you take a shot along the fairway, the device records your shot distance so you can view it later.
TIP: Automatic shot detection works best when you wear the device on your leading wrist and make good contact with the ball. Putts are not detected. To detect putts automatically, you must use an Approach® golf club tracking accessory and enable club tracking (Golf Settings).
  1. While playing golf, press Upper-right button.
  2. Select Measure Shot.
    Your last shot distance appears.
    NOTE: The distance automatically resets when you hit the ball again, putt on the green, or move to the next hole.
  3. Press Upper-right button and select Previous Shots to view all recorded shot distances.
    NOTE: The distance from the most recent shot also displays at the top of the hole information screen.
Manually Measuring a Shot
You can manually add a shot if the watch doesn't detect it. You must add the shot from the location of the missed shot.
  1. Take a shot and watch where your ball lands.
  2. From the hole information screen, press Upper-right button.
  3. Select Measure Shot.
  4. Press Upper-right button.
  5. Select Add Shot > Check mark.
  6. If necessary, enter the club you used for the shot.
  7. Walk or drive to your ball.
The next time you take a shot, the watch automatically records your last shot distance. If necessary, you can manually add another shot.
GUID-708A8F4D-9A78-49CF-9528-DE109BBCC472 v1
August 2026
