Specifications
Battery type
Rechargeable, built-in lithium-ion battery
Water rating
10 ATM1
4 ATM Dive (EN 13319)2
Operating and storage temperature range
From -20º to 45ºC (from -4º to 113ºF)
Charging temperature range
From 0º to 45ºC (from 32º to 113ºF)
Underwater operating temperature range
From 0° to 40°C (from 32° to 104°F)
Decompression model
Bühlmann ZHL-16C
Depth sensor
Accurate from 0 m to 40 m (0 ft. to 131 ft.) complying with EN 13319
Resolution (m): 0.1 m until 45 m
Resolution (ft.): 1 ft.
Inspection interval
Inspect parts before each use for damage. Replace parts as needed.3
fēnix® 9/9 Pro wireless frequencies and transmit power
M/N: A05418, A05419, A05420, AA5168, AA5169, AA5170, AA5171, AA5172
2400 - 2483,5 MHz: < 20 dBm
13,56 MHz: < 42 dBuA/m @ 10 m
fēnix 9 Pro - inReach® wireless frequencies and transmit power
M/N: A05168, A05169, A05170, A05171, A05172
LTE (B3, B8, B20): < 25 dBm
NTN (n255, n256): < 25 dBm
SAR values
< 4,0 W/kg limb; < 2,0 W/kg head
1 The device withstands pressure equivalent to a depth of 100 m. For more information, go to www.garmin.com/waterrating.
2 Designed to comply with CSN EN 13319.
3 Aside from normal wear and tear, performance is not affected by aging.
GUID-708A8F4D-9A78-49CF-9528-DE109BBCC472 v1
August 2026
