Calibrating the Barometric Altimeter
You can calibrate the barometric altimeter manually if you know the correct elevation or the correct barometric pressure.
  1. Go to a location where the elevation or barometric pressure is known.
  2. Select Track Manager > My Track > Elevation plot > Menu > Altimeter Setup > Calibrate Altimeter.
  3. Follow the on-screen instructions.
GUID-7048343C-0809-4926-9736-E4A24C88F1C4 v9
March 2026
