Formatting the Memory Card
The device requires a memory card formatted using the FAT32 file system. You can use the device to format your card using this file system.
You must format a brand new memory card if it is not formatted using the FAT32 file system.
NOTE: Formatting the memory card deletes all data on the card.
  1. Select Settings > Device > Storage & USB.
  2. Select your memory card.
  3. Select Settings > Storage settings > Format > FORMAT SD CARD.
  4. Select Done.
GUID-700B8BF2-F8BB-42A2-A617-3CC00CB4CCA0 v2
January 2024
