Editing a Route
- Select .
- Select a route.
- Select Edit Route.
- Select a point.
Select an option:
To view the point on the map, select Review.
To change the order of the points on the route, select Move Up or Move Down.
To insert an additional point on the route, select Insert.
The additional point is inserted before the point you are editing.
To remove the point from the route, select Remove.
Parent Topic: Routes
