Calibrating the Barometric Altimeter
You can calibrate the barometric altimeter manually if you know the correct elevation or the correct barometric pressure.
- Go to a location where the elevation or barometric pressure is known.
- Select .
- Follow the on-screen instructions.
Parent Topic: Elevation Plot
