Editing Dog Information
- From the tracking screen, select the dog you want to edit or select Device Options.
- Select Edit.
Select an option:
Select Collar Light to change the collar light mode.
Select ID to change the dog collar device ID.
Select Update Rate to change how often position data is transmitted from the dog collar device.
Select Update Share Code to change the dog collar device share code.
Select Dog Type to set which alerts are sent from the dog collar device.
Select Battery Saver to turn battery saver mode on or off.
NOTE: This automatically switches to a 2 minute update rate when the collar has 25% battery remaining. -
Select Color to set the color used to identify the dog on external devices.
Select Collar Sleep Mode to turn collar sleep mode on or off.
NOTE: When connected with the handheld device, the dog collar device can be put into sleep mode to conserve the battery when you are not actively tracking your dog. -
Select Name to edit the name of the dog.
Select Remove to remove the dog from your device.
