Network Interfaces
Your Garmin SERV™ device uses a Controller Area Network (CAN) interface to connect to compatible devices on your vehicle. This interface is required for proper equipment operation and cannot be disabled.
Your Garmin SERV device uses an Ethernet interface to communicate with other devices on your vehicle. This interface is required for proper equipment operation and cannot be disabled.
Your vehicle manufacturer may have configured your Garmin SERV device to act as a Wi‑Fi® access point.
The following services are enabled on your Garmin SERV network interfaces by default:
Garmin proprietary services
mDNS
Depending on the installation prepared by your vehicle's manufacturer, additional services may also be available on your Garmin SERV network interfaces, including HTTP and DHCP servers.
Parent Topic: Appendix
