Important Safety Information
WARNING
See the Important Safety and Product Information guide in the product box for product warnings and other important information.
WARNING
Failure to install this device according to these instructions could result in personal injury, damage to the vessel or device, or poor product performance.
WARNING
To avoid possible personal injury or damage to the device and vessel, disconnect the vessel's power supply before beginning to install the device.
CAUTION
To avoid possible personal injury, always wear safety goggles, ear protection, and a dust mask when drilling, cutting, or sanding.
NOTICE
To avoid damage to your boat, this device should be installed by a qualified marine installer. Specific knowledge of marine electrical systems is required for proper installation.
NOTICE
When drilling or cutting, always check what is on the opposite side of the surface to avoid damaging the vessel.
NOTICE
If you are mounting the device in fiberglass, when drilling the pilot holes, use a countersink bit to drill a clearance counterbore through only the top gel-coat layer. This will help to avoid cracking in the gel-coat layer when the screws are tightened.
GUID-6A3E1D9B-1E17-4069-BF5C-3C82F2202A9B v4
September 2025
