Charging the Dog Collar Device
To prevent corrosion, thoroughly dry the contacts on the collar and the surrounding area before connecting the charging clip.
Before you put the collar on the dog, remove the charging clip. If you do not remove the clip, it may become detached from the collar and become lost.
You should fully charge the battery before you use the device for the first time. Charging a fully depleted battery takes about two hours. The device will not charge when it is outside the charging temperature range ( Delta SE Dog Collar Device Specifications).
NOTE:
The dog collar device returns to factory default settings each time it is charged or turned off.
Parent Topic: Getting Started
