Map Settings
You can customize how the map appears in the map app and data screens.
NOTE: If necessary, you can customize the map settings for specific activities instead of using the system settings (Activity Map Settings).
Hold MENU, and select Map.
Map Manager
Shows the downloaded map versions and allows you to download additional maps (Managing Maps).
Dark Mode
Sets the map colors to either a white or black background for daytime or nighttime visibility. The Auto option adjusts the map colors based on the time of day.
High Contrast
Sets the map to display data with higher contrast, for better visibility in challenging environments.
Orientation
Sets the orientation of the map. The North Up option shows north at the top of the screen. The Track Up option shows your current direction of travel at the top of the screen.
Auto Zoom
Automatically selects the zoom level for optimal use of your map. When disabled, you must zoom in or out manually.
Track Color
Changes the track log color.
Lock on Road
Locks the position icon, which represents your position on the map, onto the nearest road.
Detail
Sets the amount of detail shown on the map. Showing more detail may cause the map to redraw more slowly.
Symbol Set
Sets the chart symbols in marine mode. The NOAA option displays the National Oceanic and Atmospheric Administration chart symbols. The International option displays the International Association of Lighthouse Authorities chart symbols.
August 2025
