Sharing a Location From a Map Using the Garmin Connect App
NOTICE
It is your responsibility to use discretion when sharing location information with others. Always ensure you are aware of and comfortable with the individual with whom you share location information.
NOTE: This feature is available only if your course-compatible Garmin® device is connected to an iPhone® device using Bluetooth® technology.
You can share location information and data from Apple® Maps to your compatible Garmin device.
  1. From Apple Maps, select a location.
  2. Select Share symbol > Garmin Connect symbol.
  3. If necessary, from the Garmin Connect™ app, select the Garmin device.
    A notification appears in the Garmin Connect app indicating that the location in now available on your device (Starting a GPS Activity From a Shared Location).
August 2025
