Important Safety Information
WARNING
See the Important Safety and Product Information guide in the product box for product warnings and other important information.
WARNING
You must install this device securely according to these instructions. Failure to install this device in accordance with these instructions could result in serious personal injury, damage to the device and/or vehicle, or poor product performance.
WARNING
To avoid possible serious personal injury or damage to the device and the vehicle, you must disconnect the power supply to the vehicle's audio system before beginning to install the device.
WARNING
Continuous exposure to sound pressure levels over 100 dBA may cause permanent hearing loss. The volume is typically too loud if you cannot hear people speaking around you. Limit the amount of time you listen at high volume. If you experience ringing in your ears or muffled speech, stop listening and have your hearing checked.
WARNING
The product contains magnets that may interfere with medical devices. Consult your physician and medical device manufacturer with questions.
CAUTION
To avoid possible personal injury, always wear safety goggles, ear protection, and a dust mask when drilling, cutting, or sanding.
NOTICE
The product contains magnets that may cause damage to some electronic devices. Use caution using the product near electronic devices.
NOTICE
When drilling or cutting, always check what is on the opposite side of the surface to avoid damaging the vehicle.
NOTICE
It is strongly recommended that you have your audio system installed by a professional installer to ensure optimum performance.
You must read all installation instructions before beginning the installation. If you experience difficulty during the installation, go to support.garmin.com for product support.
GUID-646627E3-A1E7-4EC4-BE08-216FEA26B9C3 v1
July 2025
