Setting Up the Cloverleaf Pattern
You can adjust the distance from the waypoint at which the autopilot turns your boat for another pass over the waypoint. The default setting turns the boat at a range of 1000 ft. (300 m) from the active waypoint.
between the waypoint and the location where the autopilot turns the boat
- Select .
Select
or
to set the range.
- Select Done.
Parent Topic: Cloverleaf Pattern
