User Autopilot Settings
Select .
- Power Mode
Sets the device power mode to normal or economy mode. Economy power mode allows you to set the percentage of power used to run the autopilot.
- Power Saver
Controls the aggressiveness of the autopilot. The autopilot makes fewer adjustments in power saver mode.
- Wind Limiter
Slows the rate of turn as the wind direction approaches the stern, when in sailboat mode during a gybe. If the rate of turn is too slow, decrease this value. If the rate of turn is too fast, increase this value.
Parent Topic: Device Configuration
