Syncing the Time
Each time you turn on the device and acquire satellites or open the Garmin Connect™ app on your paired phone, the device automatically detects your time zones and the current time of day. You can also manually sync the time when you change time zones, and to update for daylight saving time.
  1. Hold MENU.
  2. Select System > Time > Time Sync.
  3. Wait while the device connects to your paired phone or locates satellites (Acquiring Satellite Signals).
    TIP: You can press DOWN to switch the source.
Copyright © Garmin. All rights reserved.GUID-61792F90-CAB8-4B7C-954A-1E1A080A6FB6 v6
