Activity Map Settings
You can customize the appearance of the map data screen for each activity.
Hold MENU, select Activities & Apps, select an activity, select the activity settings, and select Map.
Configure Maps
Shows or hides data from installed map products.
Map Theme
Sets the map to display data optimized for your activity type. The System option uses the preferences from the system map settings (Map Themes).
Use Sys. Settings
Enables the watch to use the preferences from the map system settings (Map Settings). When this setting is disabled, you can customize the map settings for the activity.
Restore Theme
Allows you to restore default map theme settings or themes that have been deleted from the watch.
Copyright © Garmin. All rights reserved.GUID-61792F90-CAB8-4B7C-954A-1E1A080A6FB6 v6
