Adjusting the Depth of the Spy Pole Mount
You can change the depth of the Spy Pole™ mount after it has been installed. The device can slide up or down, depending on where you have installed the depth ring along the pole.
If you installed the Spy Pole™ mount on a trolling motor, you must set the depth-indicator ring at a point that prevents the Spy Pole™ mount from being lowered deep enough to contact the propeller of the trolling motor. If the trolling motor propeller contacts the Spy Pole™ mount, it can damage the Spy Pole™ shaft, any attachments on the pole, and the propeller.
