Pairing a Spy Pole Heading Sensor
A Spy Pole™ mount can pair to one heading sensor at a time. The Spy Pole™ mount is already paired with the included sensor, but you can also initiate pairing manually if needed. If you have multiple Spy Pole™ mount, a single heading sensor can connect to up to 4 Spy Pole™ mounts.
If you already have a reliable NMEA 2000® heading sensor connected to a Garmin® chartplotter, you do not need to install the heading sensor. The advanced control modes for the Spy Pole™ mount will work as intended with your existing heading sensor.
