WARNING
See the
Important Safety and Product Information guide in the product box for product warnings and other important information.
A battery is already installed in the Spy Pole™ gesture remote, and you can replace it when necessary.
Remove the gesture remote from any
remote mount.
Using a #1 Phillips screwdriver, unscrew
the three screws on the back of the remote.
Remove the back of the remote to access the battery terminal.
Remove the dead battery and dispose of
it safely.
You may need to use a flat prying tool to remove the battery from the housing.
Place the new battery in the back
housing, with the positive (+) side facing down.
Place the back of the housing onto the
remote and secure it using the three screws you removed previously.
NOTICE
You must tighten the screws enough to fasten the back housing onto the remote
securely. Improperly tightening the screws to secure the back housing can lead to
water ingress and damage the remote.
