Spy Pole Mount Specifications
Weight (motor, mount, and cables) |
42 in. model: 4.1 kg (9 lbs) 49 in. model: 4.24 kg (9.35 lbs) |
Operating temperature |
From -5° to 55°C (23° to 131°F) |
Storage temperature |
From -40° to 85°C (-40° to 185°F) |
Power cable length |
2 m (6.6 ft) |
Input voltage |
From 10 to 45 Vdc |
Input amperage |
1.5 A RMS 7 A Peak |
Fuse information |
8 A (included) |
Power usage |
Off: <10 mW Typical: 18 W Max: 70 W |
Radio frequency |
2400 - 2483.5 MHz @ <20 dBm nominal |
Water rating |
IEC 60529 IPX71 |
Compass safe distance |
48.3 cm (19 in.) |
Parent Topic: Specifications
1 The device withstands incidental exposure to water of up to 1 m for up to 30 min. For more information, go to
www.garmin.com/waterrating.
