Connection Types and LED Behavior
The HRM 600 supports both secure and open connections types.
Secure
The secure Bluetooth® connection type is encrypted and authenticated. For a list of Garmin® devices that support forming secure connections, go to garmin.com/hrm_connection_types. Some Garmin devices may require a software update.
When the HRM 600 is active and using a secure connection, the LED flashes Green Green (2 times) every 5 seconds.
Open
The open connection type supports all Garmin devices that are compatible with heart rate monitors. ANT‍+® connections and some Bluetooth connections are open. The open connection type is also recommended for Bluetooth pairing with third-party smartwatches, tablets, or fitness equipment.
When the HRM 600 is active and using an open connection, the LED flashes Green Green Green (3 times) every 5 seconds.
TIP: Stay 10 m (33 ft.) away from other heart rate monitors while pairing.
GUID-5BA20A50-BFFF-4418-AE4E-CA719C39EB05 v6
November 2026
