Timing Gates
WARNING
Always ride under control when using the Timing Gates feature. Failure to ride safely and responsibly could result in serious personal injury or property damage.
When connected to a GPS satellite signal, you can use your Edge® bike computer to create a timing gate series, using locations along a route to record split times over multiple runs through the virtual gates. Each circuit through the timing gate is known as a run. During a ride, the bike computer records a split time when you pass a gate, and indicates if the split was faster or slower than the split from the fastest run in that ride.
Timing gates split summary with data
After the ride, the bike computer summarizes the splits to show the best run between each gate.
On your Garmin Connect™ account, you can view a detailed post-ride analysis of all runs through each gate.
GUID-5BA20A50-BFFF-4418-AE4E-CA719C39EB05 v6
November 2026
