Selecting Alternate Data During a Ride
During a ride, you can temporarily replace a data field that has unavailable data. Alternate data fields can be set any time during the ride.
  1. Go for a ride (Going for a Ride).
  2. Swipe left or right to view a data screen.
  3. Hold a grayed out data field.
    NOTE: Data fields with unavailable data appear grayed out approximately 15 seconds after you start the activity timer.
  4. Select Edit symbol > Select Alternate Data.
  5. Select a data field with unavailable data.
  6. Select a category, and select a new data field.
    The alternate data icon turns blue.
  7. Select Back arrow symbol.
The alternate data field appears, replacing the primary data field.
TIP: You can also set up alternate data fields prior to your ride (Setting Up Alternate Data Fields).
GUID-5BA20A50-BFFF-4418-AE4E-CA719C39EB05 v6
November 2026
