Customizing the Widget Loop
You can change the order of widgets in the widget loop, remove widgets, and add new widgets.
  1. Select Menu symbol > System > Widgets.
  2. Select an option:
    • Select Plus symbol to add a widget to the widget loop.
    • Select Rearrange the menu symbol to drag the widget up or down to change the location of the widget in the widget loop.
    • Swipe left on a widget, and select Delete symbol to remove the widget from the widget loop.
GUID-5BA20A50-BFFF-4418-AE4E-CA719C39EB05 v2
November 2025
