Viewing Your Real-Time Stamina
Your device can provide real-time stamina estimates based on your heart rate data and VO2 max. estimate (About VO2 Max. Estimates). How hard you are working during an activity affects how quickly your stamina drains. Real-time stamina tracking works by combining your physiological metrics with your recent and long-term activity history, such as training duration, distance covered, and training load accumulation (Performance Measurements).
NOTE: For best results, record cycling activities with a power meter consistently for 2 to 3 weeks and with different intensity levels and duration.
  1. Select Menu symbol > Activity Profiles.
  2. Select a biking profile.
  3. Select Data Screens.
  4. Scroll left or right to view the Stamina data screen.
  5. Select Data screen settings symbol.
  6. Select Show Screen to view the data screen during your ride.
  7. Select Show Current Effort to select the stamina option.
  8. Select Show Distance or Show Time as the primary data field.
  9. Select Edit Data Fields.
  10. Select Plus symbol or Minus symbol to change the layout.
  11. If necessary, tap a field to swap it with another field, or hold a field to edit it.
  12. Select Checkmark symbol.
  13. Go for a ride (Going for a Ride).
  14. Swipe left or right to view the data screen.
    Stamina data
    1
    Primary stamina data field. You can view the estimated time or distance remaining until you will reach exhaustion at your current effort level.
    2
    Potential stamina estimate. Think of potential stamina as the total capacity of your fuel tank. It will decrease quickly if you are riding at a high effort level. Reducing your effort or resting results in a slower decline of your potential stamina.
    3
    Current stamina estimate. Your current stamina reflects how much you have left in the tank at your current level of effort. This estimate combines general fatigue with anaerobic cycling activities, such as sprints, climbs, and attacks.
    Red Red: Stamina is depleting.
    Orange Orange: Stamina is steady.
    Green Green: Stamina is recharging.
GUID-5BA20A50-BFFF-4418-AE4E-CA719C39EB05 v5
September 2026
