Calibrating the Compass
NOTICE
Calibrate the electronic compass outdoors. To improve heading accuracy, do not stand near objects that influence magnetic fields, such as vehicles, buildings, and overhead power lines.
Your device was already calibrated at the factory, and the device uses automatic calibration by default. If you experience irregular compass behavior, for example, after moving long distances or after extreme temperature changes, you can manually calibrate the compass.
  1. Select Menu symbol, System > Calibrate Compass.
  2. Select Calibrate, and follow the on-screen instructions.
GUID-5BA20A50-BFFF-4418-AE4E-CA719C39EB05 v2
November 2025
