Power Guide
You can create and use a power strategy to plan your effort on a course. Your Edge® device uses your FTP, the course elevation, and the projected time it will take you to complete the course to create a customized power guide.
One of the most important steps in planning a successful power guide strategy is choosing your effort level. Putting a harder effort into the course will increase the power recommendations, while choosing an easier effort will reduce them (Creating a Power Guide). The primary goal of a power guide is to help you complete the course based on what is known about your ability, not to achieve a specific target time. You can adjust the effort level during your ride.
Power guides are always associated with a course and cannot be used with workouts or segments. You can view and edit your strategy in Garmin Connect™ and sync it with compatible Garmin® devices. This feature requires a power meter, which must be paired with your device (Pairing Your Wireless Sensors). After the devices are paired, you can customize the optional data fields (Data Fields).
Power Guide data
Before you can create a power guide, you must pair a power meter with your device (Pairing Your Wireless Sensors).
  1. Select Training > Power Guide > Plus symbol.
  2. Select an option:
    • Select Use Saved Course to use a saved course, and select the course.
    • Select Course Creator to create a new course, select Save, enter a name for the course, select Checkmark symbol, and select Create Power Guide.
  3. Enter a name for the power guide, and select Checkmark symbol.
  4. Select a riding position.
  5. Select a gear weight.
  6. Scroll to review the power guide details (optional).
  7. Select Save.
Starting a Power Guide
Before you can start a power guide, you must create a power guide (Creating a Power Guide).
  1. Select Training > Power Guide.
  2. Select a power guide.
  3. Select Ride.
  4. Press Start stop symbol to start the activity timer.
GUID-5BA20A50-BFFF-4418-AE4E-CA719C39EB05 v6
November 2026
