Calibrating the Barometric Altimeter
Your device was already calibrated at the factory, and the device uses automatic calibration at your GPS starting point by default. You can manually calibrate the barometric altimeter if you know the correct elevation.
  1. Select Menu symbol > System > Altimeter.
  2. Select an option:
    • To calibrate automatically from your GPS starting point, select Auto Cal..
    • To enter the current elevation manually, select Calibrate > Enter Manually.
    • To enter the current elevation from the digital elevation model (DEM), select Calibrate > Use DEM.
    • To enter the current elevation from your GPS starting point, select Calibrate > Use GPS.
GUID-5BA20A50-BFFF-4418-AE4E-CA719C39EB05 v2
November 2025
