Resetting the Edge Bike Computer
If the bike computer stops responding, you may need to reset it. This does not erase any of your data or settings.
Hold Power on off symbol for 12 seconds.
The bike computer resets and turns on.
Restoring the Default Settings
You can restore the default configuration settings and activity profiles. This will not remove your history or activity data, such as rides, workouts, and courses.
Select Menu symbol > System > Device Reset > Reset Default Settings > Checkmark symbol.
Clearing User Data and Settings
You can clear all user data and restore the device to its initial setup. This removes your history and data, such as rides, workouts, and courses, and resets the device settings and activity profiles. This will not remove any files you added to the device from your computer.
Select Menu symbol > System > Device Reset > Delete Data and Reset Settings > Checkmark symbol.
GUID-5BA20A50-BFFF-4418-AE4E-CA719C39EB05 v2
November 2025
