Pairing the HRM 600 with the Garmin Connect App
On the
HRM 600 module, press the button to wake it up.
The LED flashes
when it is active and transmitting.
- From the app store on your phone, install and open the Garmin Connect™ app.
Hold the button for 4 seconds to enter pairing mode.
The LED flashes
continuously.
The HRM 600 is in pairing mode for 5 minutes.
To end pairing mode, you can press the button.
Select an option to add your
HRM 600 to your
Garmin Connect account:
If this is the first time you are pairing a device with the Garmin Connect app, follow the on-screen instructions.
If you have already paired another device with the Garmin Connect app, select
> Garmin Devices > Add Device, and follow the on-screen instructions.
Parent Topic: Pairing the HRM 600 with Your Compatible Device
