SOS
WARNING
Before you can use the SOS function, you must have an active satellite subscription. Always test your device before you use it outdoors.
WARNING
Ensure you have a clear view of the sky when using the SOS function, because this feature requires satellite access to operate properly.
NOTICE
Some jurisdictions regulate or prohibit the use of satellite communications devices. It is the responsibility of the user to know and follow all applicable laws in the jurisdictions where the device is intended to be used.
During an emergency, you can use your paired inReach® satellite communicator to contact the Garmin Response℠ center to request help. The SOS feature sends a message to the Garmin Response team, and they notify the appropriate emergency responders of your situation. You can communicate with the Garmin Response team during your emergency while you wait for help to arrive. You should only use the SOS function in a real emergency situation.
GUID-5AE59F95-4268-47C5-8D27-DC4B4F41E230 v3
December 2025
